If you are satisfied with your lighting setup, bake the final version of the lightmap. For the final lightmap baking, we recommend using at least 800 Samples.
To bake the high-quality version of the lightmap go to the Bake tab. Set the number of Samples to at least 800 and click the Bake button.
âť• The process of baking the final version of your model might take from a few to 24 hours depending on your computer and the size of your model.
âť• Changing the Material properties or adding Views or Extensions does not require baking the scene again.
