1. Export a 3D model from your 3D modelling program
Shapespark supports the following 3D file formats: FBX, COLLADA (DAE) or OBJ.
β If you use SketchUp, Revit or 3ds Max use a Shapespark extension to export your model.
(The extensions will be installed automatically together with the Shapespark program. Both the SketchUp/Revit and Shapespark applications should be running during the export.)
For more instructions, we have dedicated articles on exporting a model from SketchUp, 3ds Max, Revit, Maya and Cinema 4D. For other 3D modeling programs try one of the supported 3D file formats (FBX, COLLADA or OBJ).
If you donβt have your own 3D model ready you can use this example-room SketchUp model from Sketchup Warehouse to test out Shapespark functionalities.
2. Import a 3D model into Shapespark
β If you use SketchUp or Revit, use the Shapespark extension instead.
Open the Shapespark desktop application and click the Import .fbx .dae .obj button. (The supported 3D model file formats are: FBX, COLLADA (.dae) and OBJ.)
